Port Waikato Dunes
ABFoz
Auckland, New Zealand
Forester XS
4EAT
I went to Port Waikato a few weeks ago as I was supposed to go to Rangipo and do some desert touring but it experienced some snowfall and they had to close Desert Road. Port Waikato has the highest concentration of heavy metals anywhere on the planet and I wanted to have a look at some samples. Since this is not necessarily remote, as it is just on the town of Port Waikato itself, it is still like just a weekend off-road fix for somebody living in Auckland. It is also a chance to take some photos of this piece of land where the meeting point of the mighty Waikato River and the Tasman Sea can be viewed.
As usual, since the trails are in the sand, the vegetation growth is prominent and I had to weave around to minimise the pinstriping
Some trails are too narrow and horse tracks are the only ones that are left on it. This one is a narrow horse trail and I went up it to be able to take photos of the surroundings
The area has evident concentrations of iron sand.
Over there in the forest, there is a mine just to take advantage of such concentrations. I used to visit the area for some research.
This rip is not as sneaky as the others.
I went to another narrow trail and as soon as I turned, I noticed that there aren’t that much tracks and I was tilting almost all the way. The right hand side is the drainage and is very, very soft. This trail may be too narrow for a bigger vehicle.
It was OK until I slowed to a halt. I encountered the mushy part and my car is just 5cm away from the vegetation and compacted sand. I remained on the left-hand side but the car slid to the right. I could claw up using the vLSD but the rear-right wheel turns much faster than the rear-left. In this photo, both right wheels have the least resistance.
(Footprint of a recovery board)
I decided to use the recovery boards to make sure the moment the wheels turn, the car moves forward. These boards are a must to any modern-day off-roader. You can have a winch but recovery boards can be used anywhere, especially if there are no anchor points for the winch.
I forgot to turn off the recording on my phone and it captured my 7 minutes minute recovery.
With our previous 4x4s, I used to do sand recovery without boards. The boards just make everything much, much easier.
After getting out, I took a few more photos of the surroundings.
Then I am supposed to pass by Klondyke Road, which is somewhat less-maintained, tohave a look at some outcrops but while I was airing up my 2nd tyre, my 37 litres/min cheap tyre inflator started to make noise. On the third, It gave up at around 28 psi. The last tyre was still at 17 psi.
I felt OK because there was a dairy around 300m away which sold fuel so I assumed it would have air, as well. I was wrong. I had to travel at a really low speed. I encountered a 4x4 which looked like he does off-roading. He didn’t have a tyre inflator. The next gas station was just 30 km away but I had to tread slowly to preserve my tyres. I aired up at Tuakau and headed home.
Because of the tyre inflator blues, I bought a heavy duty 160 litre/min tyre inflator from a 4x4 shop. It is much more robust than anything I had used before.
Thanks for sharing your kiwi adventures !
On a side note, I use a manual bicycle air pump....its healthy and never lets you down !
Gorgeous part of the world you got there.
Cheers, mates. I am truly happy to share the trips with the dirt-loving community!
I have an '06 model SG and they do hold their own on the sand pretty well hey!
True, these vehicles perform excellent on loose surfaces. Cheers.
