I am able to test drive the SK recently and I would like to share my insights.
Unlike in the US, we do not have a specific place to test the vehicle on the dirt. There may have been an event before but those were only for journalists.
Room: There's plenty of room just like the SJ. That may be the reason why many choose the Forester after coming from real 4x4s. There are even more hooks and points of attachments than ever. Subarus are very utilitarian.
Visibility: The designers are able to maintain Subaru's trademark visibility while adopting a newish design.
Handling: On chicanes, I noticed that it has a lower roll-rate but much higher roll-speed vs the older models. It is able to do this while it has high frequency dampening. That's just good engineering.
Infotainment: It is good and functional but the worry about this comes out when software support has expired. I have seen newer vehicles with double DIN adapters and updated head-units and they seem to perform better than built-in entertainment systems. There isn't really that much of an advantage here with the newer models. In fact, if one has a double DIN pocket, he/she can immediately get that new car infotainment system by installing top-of-the-line models from good brands.
Drivetrain: The CVT belt tightens much more quickly than the previous models. The torque converter has a very aggressive lock-up, like what I experience with my SportShift. Power delivery is impressive. If I am going to take this off-road, I would just use manual mode to make sure that the ratio is locked up and the CVT belt won't keep searching for the best ratio all the time, increasing wear in the process.
EyeSight: It's the best in class as it's very active and 2 cameras are better than 1. That being said, I still prefer my own eyesight.
Not much here. I keep my cars as long as possible but test newer models every 10 years to check if I am missing something. I do this in my spare time or after a meeting around Wairau Park, where the dealers are located.
For me, if one owns a Subaru that has the Ring-shaped Reinforcement Frame, there is no need to upgrade, unless more room is required. Cheers.
