I'd thought about doing that too.
Any clue what that would take? Man I wish I wasn't such a newb when it comes to mechanical stuff.
In lots of ways I agree with what frogstar is saying about the AT,
but I did research it quite a bit back in the day when I wanted to do it,
so your getting my .02 if you like it or
not.
Besides the adapter plate you will need a tranny, they didn't change too much over the years but I'd try to find one with the lowest reduction. I believe the last year with dual range in the US was '89. Check out
cars101 and I believe you will find the answer. Probably finding one locally would be the best bet, but also contact Ben at Hodges,
service@hodgessubaru.com ,a while back he said they had some old tranny's kickin' around last I talked to him, and I'll bet he would love to contribute to this project if at all possible.
I don't
think you'll need a redrilled flywheel putting an EA tranny mated to an EJ engine, but e-mail Allied to check for sure. The other question there is which clutch to use???
Do it and you will be an uber-hero!!!:biggrin: Don't forget, for DD purposes you will only be FWD. Another question would be matching up diff ratios, but again, I don't think that would be too much of a problem since they haven't changed that much over the years.
AT or DR swap and your probably going to spend at least a grand, on the other hand if you get a "true" 4X4 that grand will come and go just as quick on other things. Build what you've got or buy and build some more.
