TY752XRAAA LR Ratio.
dostawca
Poland
WRX
Manual
Hello, I'm looking for LR ratio in this box.
Rest of ratios are known.
Code:
EU Legacy 2.0 MY95-97	TY752XRAAA	3.545	2.111	1.448	1.088	0.871	N/A	3.416	1.000	3.9	Viscous (4kgf)	Open
My brother-in-law has this box and it happens to have same 3,9 as my rear diff.
It's cable clutch not pump like mine.
Can't find any info on gearing in low range, could it be 1,44 from sf foz?
Easy !
Rotate the output shaft 10x in high range first gear and you will get 35 rotations and 28 minutes on the input shaft (10x3,545=35,45)
Repeat same operation in low range (35,45x1,447=51,29) and with a 1,447 gearing you should find 51 rotations and 17 minutes on the input shaft
Hope it helps !
Was hoping not to do it, as it lays under many wheels and tyres in garage ;)
Thanks, I'll do it as soon as I get rid of ton of wheels.:rotfl:
Ok, so from OF I've found gear no which only relates to this post in google only this is the same[35206AA060-25teeth] rest is different.
I'll be in garage this weekend so we will check this if I won't find anything on web.:poke:
