Axle Question SF/SG
Ben Up North
can only hope to improve
FNQ
2004 | 1992
SG Forester X MY05 | 92 SVX
5MT D/R | 4EAT
I don't suppose they're the same part?
i.e SF Forester Front will go into SG front, SF Rear will go into SG rear..?
Had a look on autopartswarehouse and it seems they're the same, can anyone confirm?
Some might. You need firstly to check whether the inners are male or female. Abs rings differ also on the front.
No they're different. SF is female on the gearbox end, SG is male. They may also be slightly different lengths
Rear axles should be the same, depending on the rear diff. Some SF GTs have the type 1 viscous LSD which use asymmetric axles
Early SG's can also be male and 4EAT's (may) have studs, all this can be mixed up ! Talking about the front CV's that is.
