2008 outback lift kits!
FunnY
Perth
Outback
4 speed Auto
Hey there all,
I'm the proud new owner of my first subaru! its a 2008 outback! and can't wait to take it down bush tracks and fire trails.
I bought the car this Monday just gone (17th SEP) and want to put a small lift on, 30mm or even 25mm would be enough. I'm planning on having 215/60R17 Bridgestone duelers as well. The tyres will add about 15mm or so to the total roof height so the lift can't be more than 35mm because the car will then be more than the legal lift height of 50mm in Western Australia.
So i've tried asking everywhere i can and can't find much. Mechanics ether don't want to help or don't care about my dreams of lifting my outback so i went online looking for parts and this is the closest i've come to a lift kit.
https://www.ebay.com.au/itm/SUBARU-...LIFT-KYB-SHOCKS-COIL-SPRINGS-KIT/321199115340
So basically the questions i have is do i need new shocks or will the OEM subaru ones be ok with king springs, will i have to also install longer camber/alignment bolts and if so am i better off going with something more like this
https://www.gumtree.com.au/s-ad/mul...mm-bh-bp-outback-99-09-gen-3-gen-4/1152897181
cheers.
Isaac, aka.FunnY
Join the Subaru 4WD Club of WA, heaps of experienced people there who can help you out!
Lift Kits, there are a number of Vendors, with SubieLift Oz, ADF, Subtle Solutions being the main ones
Buy Australian! (SubieliftOz) Gotta be cheaper than the Yanks at the moment :)
AFAIK there aren't off the shelf longer shocks to go with the lifted springs. That means the shock travel won't quite match the spring travel. But heaps of people run that combination anyway. The King springs will be firmer, so I would recommend them if you load up heavy or want a firmer ride. If not then I would recommend the Subilift Oz spacer kit. The 2" spacers tend to be easier to fit then 1" spacers as they don't need to replace the standard studs with longer bolts. The 1" lifts with out camber offset get OK wheel alignments, but not ideal like the 2" camber/caster kits. So a few things to consider depending on what you want out of it.
hey mate I'm in WA with a 2 inch subie oz lift kit on my 2006 H6 outback
Hey everyone,
thanks for all you input i have decided to go with the 2 inch lift from subiliftoz, i have been in contact with Matt over there and he is very good at what he does.
Red XS - thanks for your info, I have gone off your recommendation and opted for the 2 inches mostly for the ease of installation and to keep ride quality, only thing is im putting in saggy butt spacers to give a little bit more room for weight.
thanks guys! big help!
I'm going to start another thread soon and will be posting pics and story of me and the BP getting upto no good on weekends! haha
Hey WaynieRS.
Can you post some pictures of your car would love to see them!
FunnY.
thats as i bought her
this is with the 2 inch lift kit
Had these tyres a year ago, I was happy with them !
i bought these tires that were mounted on a set of 16inch toyota 86 rims for $400 Aus.... general grabbers ... yet to try them off road but i knew my limiting factor was road tires . will be disconnecting my drop links for my next adventure
They are very good tyres, only concern is the fragile sidewall, and also a bit slippery on the wet.
That's awesome man! Thanks for sharing.
I like the bull bar with the light bar as well. I'm thinking I'm going to keep my bumper and put a nudge bar on with some spot light
I'm also going to be putting on some A/T tyres I'm going with these. (Wanted to keep stock rims even though couple of them has pretty bad curb rash)
https://www.tyresales.com.au/buy/tyre/bridgestone/dueler_a-t_d697/215-60r17/138556?q=undefined
I've spoken to matt at subilift oz again he said I will be able to put a mother half inch spacer on the rear for only another $30 so I'm thinking I'm going to do that so acout for camping gear in the back.
I'll post some pics soon of my can stock! Have a good one
Hey Waynie,
with your tyres what size are they and did you have to remove the mud guards so you didn't bind?
thanks man,
FunnY.
nice look. subarus looks better with AT tires. not too much agresive here but not bad.
so how much ground clearance you got now front middle rear diff. ?
