Blue Fox
- Dec 29, 2009
- 198
- Durango, Colorado
- 2005
- Forester XT - 2" Lift
- 5MT Dual-Range
Hello everyone,
I have completed the SF Dual-Range into my 2005 Forester XT. The transmission is working well, however I have an issue with what I believe is clutch engagement/disengagement, but perhaps something else?
What I have:
SF 1.44 Dual-Range
N/A US Forester Flywheel from 2005 Forester
N/A US Forester Exedy Stock Clutch
The Issue:
Driving the car needs great care to slowly release the clutch or it will clunk rather loudly (and you'll feel it). If you get under the car and someone slowly lets out the clutch, you can hear it sort of "clunk". It almost feels like the clutch is on/off instead of fluid in the pedal travel. I have bled it properly numerous times and can see it working smoothly.
Another thing that will happen (not sure if separate issue or part of the same) is when off road, even if not slipping the clutch all that often or at all, I will get a squishy clutch pedal randomly, and will have to pump it a few times to get it to come back to normal firmness. No smell of clutch burning at any time really.
And the LAST thing I've noticed is that my very loudly whining first gear seems to continue to whine faintly even when the clutch is pushed all the way in and I am still moving.
I am not sure if I have the wrong thickness of flywheel (and if so, is it too thick or not thick enough). Or is there something else going on like a faulty slave/master, or even the possibility of the front diff having a bit of slack? I'm at a loss. Any help would be appreciated.
What I have:
SF 1.44 Dual-Range
The Issue:
