OBD2 apps that show DPF data
Dunco
Townsville, Australia
Manual
Hi guys,
I'm on the look out for a decent paid app to used with my obd2 scanner which is a ELM 327.
I've got a Forrester 2010 S3 2.0D and I'm keen to get some data on how my DPF is performing.
There are loads of free ones that work great but I'm wondering if anyone has one that show DPF ash accumulation, regenerative status and timing.
Every so often the DPF light comes on flashing and it would be nice to know if it's just an oil dilution issue or that the dpf is clogged and needs a regen.
Thanks in advance
Dunco
As far as i found best app for that is torque pro. And ppl using that on newer foresters as well. It will show you real time data , errors and some test results with values temps and such. And you can use some custom pids with torque as well.
