Subforest72
I recently swapped my EJ202 for an EJ251 that worked perfectly until a tree branch broke the timing case and the crankcase gasket passed through the belt, offset timing and twisted valves
I have a pair of EJ201 heads (similar to EJ202 heads) in my garage, I think bolts them on EJ251 engine block
someone has already make it?
the idea is to increase the compression ratio a little
