GC Parts
LiftedWRX
WV
Parts are from 1999 and 2000 RS coupes both 5 speeds.
Located in Fairmont WV or shipping isn't a problem just message me for a quote. If you want pictures of a certain part or interested in something not listed just ask.
*Links to albums of individual pictures of each part are located beside each group*
GC Parts
Engine & Drivetrain Pics: • EJ22 Longblock $400
• EJ22 Intake Manifold $100
• EJ22 Throttle Body $60
• EJ22 Engine Harness $50
• 04 RS SOHC Complete Heads $200
• Lightweight Flywheel $60
• 6 puck with pressure plate $60
• Airbox $30
• Crankshaft Pulley $30
• Plug Wires $30
• Air Assist Injector $35
• Timing Covers $10 each
• Power Steering Pump with reservoir $75
• Power Steering Pump Bracket $10
• AC Compressor $80
• AC Compressor Bracket $10
• AC Tensioner $25
• Rear subframe $40
• Engine crossmember $80
• Rear differential carrier 'T' subframe $50
• Rear differential $50
• Transmission subframe $25
• 5 speed transmission $400
• Transmission mount $20
• Gas cap $10
• Fuel pump $20
• Fuel pump assembly $20 (1 piece broken)
• Fuel lines $50
• Fuel pressure regulator $25
• Injectors $40 set
• Clutch master $30
• Slave cylinder $30
• Steering rack $75
• Throttle cable $10
• Ignition coil $20
• Plug wires $40 set
• Throttle body $40
• Oil fill neck and cap $15
• Cam gears $10
• Axle with one busted CV joint $25
• Intake silencer $10
• Coolant overflow tank $10
• Radiator fans $25 each
• Valve covers $40 set
Suspension & Brakes Pics: • Sway bars $30 each
• Lateral links $20 each
• Trailing arms $40 set
• Endlinks $20 set
• Control arms $25 each
• Brake booster and master $40
• Driver Front ABS sensor $20
Exterior Pics: • Passenger Taillight $75
• Hood vents blue $40 each
• Driver door black $100
• Rear bumper $75 (blue & black available)
• Front bumper beam $60
• Black trunk with small wing (no dents needs repainted) $50
• Blue trunk with small wing (has few dents) $50
• Inner fenders $10
• Door windows $40 each
• Hood release cable $10
• Roof trim $40 each
• Windshield trim $25 each
• Wiper cowl $25
• Wiper motor & linkage $40
• Sunroof frame $50
• Driver Taillight trim blue $20
• Taillight trim black $20 each
• Quarter panel trim $10 each
• Hood prop $5
Interior Pics: • Steering Wheel $20
• Driver airbag $40
• Dash bar $50
• Door handle $20
• Passenger Door Lock Actuator $20
• Hood release handle $5
• ECU cover $10
• Wire covers for inside door kick panel $10 side
• Fuel pump cover $5
• Gas pedal $20
• Blower motor $50
• Dash cup holder $10
• Rear view mirror $20
• Map light $10
• Seatbelts $40 (no driver front or rear center but have the rest)
• Steering column $50
• Speaker brackets $5 set
• Weatherstripping $5
• Tweeter cover $10 each
• Door handle trim and pocket $10 set
• Door panel bolt covers $5 set
• Gauge cluster surround $10
• Seat bolt covers $10 set of 4
• Passenger A pillar $15
• Rear heat vents $20 set
Electronics Pics: • Knock sensors $10 each
• Sunroof harness $10
• Interior fuse box $20
• Engine bay fuse box $20
• Door ajar sensor $10
• Horn and cruise control steering wheel switch $20
• Antenna with hardware $25
• Wiper switch $20
• Airbag sensors $10 each
• Airbag harness $25
• Alternator to battery cable $10
OP Updated. Why are my pictures so huge on here? You have to zoom out to 25% to see the entire photo
Yes, you'll need to resize them or load them to an album via User CP "pictures & albums" which will attempt to resize them. You can them link to them in your posts.
Alternatively if you use "Attach" to load them in the post an attempt is made to resize JPEG to JPEG, PNG to JPEG, GIF to JPEG.
Also I seem to recall you can add a "resize" parameter to your imgur link?
Thanks for the reply. I didn't see an option on imgur to resize but I do have it set not to upload in high quality.
I guess I could reupload them all to the pictures and albums but what is weird this is the only forum that shows the images so big. There might be a setting on your end like:
Maximum picture size (Mb) : 4.00
Maximum image length (pixel) : 1280
Maximum image height (pixel) : 1024
Then you wont have to worry about big images being linked.
@LiftedWRX I checked to limit URL links but have had no success. If you add "h" to your pic name in the imgur link you'll get the following result. imgur pic size can be controlled by appending these characters to the file name as follows:
  • s = Small Square (90×90) as seen in the example above
  • b = Big Square (160×160)
  • t = Small Thumbnail (160×160)
  • m = Medium Thumbnail (320×320)
  • l = Large Thumbnail (640×640)
  • h = Huge Thumbnail (1024×1024)
In this case the URL is https://i.imgur.com/YjC9ScUh.jpg
[MENTION=114]Kevin[/MENTION] you da man! Fixed the size of the pictures
OP updated: lowered some prices and added some new parts
OP updated with a ton of parts and added a link to new pictures of individual parts after the list
Updated the first couple of posts with new pictures and parts list.
Links to albums of more pictures are located beside each group of parts
I know this post is old but......
Any chance you still have a multi function switch for the lights?
My 93 won't turn the marker lights off unless I unplug the battery. Super annoying.
Have you tried turning the switch off that’s on top of the steering column?
