J_Jones
- Oct 30, 2017
- 4
- Chapel Hill, NC
- 2005
- Forester 2.5X
- Auto
Hello all. I have a 2005 Forester 2.5x that I would love to get a rear locker into and as such, have contacted two companies in an attempt to get that going: Aussie Locker and Lock Rite. Couldn't find contact info for Spartan. I got my first response back from the makers of the Aussie Locker, TorqMasters.com and they had a few questions that I hope you all can assist me in giving the correct info.
My message:
Hello. I was wondering if you all plan to or currently have anything in the works for Subarus? Specifically the R160 rear differential found in almost every Subaru since the early 90's (Not the r180 found in STI's, they have enough options). I know there is a high demand for something in the Subaru community and couldn't see why the venture wouldn't result in a profit. There is basically nothing available for the r160 besides the OEM optional VLSD that to be honest, is useless offroad.
Their reply:
We looked into center diff spools. I think you would have to lock the center diff to get a rear locker to work? We are not Subaru experts, so your input is appreciated.
My reply:
While a locker option for the center differential would also be nice, it isn't necessary for the rear locker to work. Manual transmission equipped Subaru's have a viscous limited slip in the center differential that give 50:50 front:rear torque distribution all the time and adjusts as needed. Automatics have either a multi-plate transfer clutch or variable torque distribution system which both vary in how much torque is sent to the rear but we have found a way of locking them with a flip of a switch so that is no longer an issue: https://www.subarufor...mand-4eat-3091/
Sorry for the long reply but short answer is yes, a rear locker will definitely be beneficial in any drivetrain configuration, even without modifying the center differential.
Their reply:
Thank you for the explanation, very helpful! Our Aussie Locker is popular in Sweden with rally Volvo's, we know they can hold up to the turbo cars well. To make a prototype we will need a rear differential and part of the axle shaft that slides into the diff. Can you tell me fitment? Which years this diff was used? I can source a local diff from a junk yard.
So that is where I am. Turns out, the person that is responding to my emails is the president of the company and sounds interested. Anyone confident in their knowledge to answer this question? I'm guessing here, but I think that they would need to source a standard open differential and associated axle. From pictures of the open vs VLSD and my experience, the VLSD would not be a good choice due to 1. the vlsd portion itself could cause issues and 2. the open differential has a much larger opening to the spider gears in comparison to the VLSD and that is how you get these type of lockers in.
From everything I have been able to find out so far, Subaru r160's are able to swap differentials from one to another without issue. While there are some external differences and axle differences, I should be able to take an open differential from any subaru with an r160, install the Aussie Locker in it, and then swap it into my car's original housing and adapt axles if necessary. Is this correct? Basically, the manufacturer is wanting to make sure that this part works for many cars, with some work of course.
From UltimateSubaru, it was suggested that an open differential from anything 95+ that has axles which insert into the differential would be the way to go for adaptability.
Sorry for the long first post but I figured you all may be interested in this. Any info is greatly appreciated. Thanks all.
My message:
Their reply:
My reply:
Their reply:
