Tweaksta
Senior Member
With used 2010 Forester Diesels starting at around $13,000 (most with between 100,000 and 200,000km on them), they are beginning to look tempting as an upgrade.
With mainly DPF, blown hoses and oil dilution issues causing the majority of noise surrounding these models I wanted to know if now, about 7 years on, these issues are easily overcome?
Thorough and regular checking of turbo and intercooler hoses or replacing them with aftermarket items would seem like the obvious solution to the hose problem
The general consensus regarding DPF issues is that those who suffer clogged DPFs don't give it enough a***holes when driving....too much lugging, low speed usage of 6th gear and short drives being the main culprit....allegedly.
So, do the DPF problems still occur if you take long drives, rev it hard, tow trailers up long hills in low gears - ie: if you regularly subject the DPF to the required temps, has anyone still had to fork out the $3000 for a new DPF? Or is a good regular fang the magic solution to this issue?
As for oil dilution, changing the oil every 5000km should fix this.
So, with so many people trying to offload their 2010 Gen 1 Diesels due to these issues have we yet found a way to make them fully reliable? Or is the whole thing only affecting a few 'lemons', and the bulk of them are fine? And if so, can these lemons be fixed?
