Indicator wiring for front bar (SG model)
Liberty Valance
Hervey Bay
2 x XT Foresters
Auto
The indicators have never been wired up in my front bar I though it was about time to get around to it...
However, where on earth do you pick up the indicator wiring ???
Looks like the headlights need to come out to get anywhere near the indicator wires, has anyone found an easier way?
I took the headlights out when doing mine. As far as I could see there was no way to access the indicator wires from underneath as there is another panel in the way. And there's too much effort trying to find the correct wire further down the line.
Wiring probably runs in one of the wheel wells - clipped to the inner side behind the plastic guard.
Surprised you can't get to the headlight connector then follow the harness?
Pulling the headlights isn't hard -- don't forget you need to be able to replace the bulbs -- on a gen3, its pop the bonnet, three 10mm bolts. 2min max.
