Tweaksta
Senior Member
One of the 4wd online mags has lumped Subarus in with all the crap AWDs - wrongly stating that our cars are capable of becoming 2wd under extreme conditions with our open centre diffs.
Have I misunderstood how our Subies work? I always thought manual turbos (and possibly others) had at least SOME drive to front and back due to there being a viscous centre diff (essentially a centre LSD).
Isn't this why the Subaru AWD system is superior to the rest?
Below is a re-type of the article's text:
(source: https://www.unsealed4x4.com.au)
Common Misconceptions:
No 7. Awd is the same as 4wd.
This is usually rolled out by those who drive AWD SUVs (not that there's anything wrong with that). In the real world, AWD may function in a similar fashion to 4wd, but unless you can lock the centre diff it'll never do the job nearly as well when the going gets rough. Sorry all you Forester guys, but there's just no getting around that fact.
AWD vehicles have an open centre diff (just like fulltime 4x4 vehicles like Range Rovers and LandCruisers), but they are unable to lock this centre diff (whereas Rangies and Cruisers can). What does this mean in the real world? Just like with unlock diffs everywhere, the rotation force put out by the engine-gearbox-transfer case will follow the path of least resistance, so despite having an AWD badge on your tailgate, there's a good chance that when you're in the rough stuff, you're actually going to be getting drive to your front or back axle only.
Is this writer an ignoramus, misinformed or just trying to bag anything that isn't a oversized 2.5 tonne smoke belcher?
Some of us have taken our Subies through situations which a larger, heavier vehicle with a locking centre failed at, and if you take a look at some of the vehicles you find way out in the centre of Australia, Subarus do actually make it to many of the place the big guys do. You don't see many of the other AWDs though. I reckon it's a bit unfair to lump us with the other AWDs. Our system is almost next level in comparison.....
