mr terriffic
- Dec 7, 2015
- 19
- Kalgoorlie
- 2005
- Forester XL
- Man
Forester '04 - Does anyone know if long range fuel tanks can be fitted and if so are they available in Aus?
SubaXtreme did make a tank to fit into the spare wheel well.
However this meant that you needed an external wheel carrier for the spare.
It may be worth exploring this, or similar option.
Otherwise not that I am aware of.
The photo above is the neatest solution I have seen for extending fuel range in a forester, it makes wonderful use of redundant space.
It would be a custom fabrication and require some very detailed work to get shape, baffles, hold down points, filler and breathers functioning properly.
Aux tank Filler pipe goes through the body work to join up with the filler pipe to main tank.
I think this is approved by Subaru. It is the standard in South Africa & in the region. I.e. Botswana, Namibia etc.
Tank is stainless steel, made by a company in SA that makes aftermarket kit for 4c4’s etc.
If someone want's to do the research on availability of that tank from South Africa I would be interested in a group purchase for the right price.
That's great thanks, if nothing else it's a neat design to copy. Interestingly I can't see a breather in the photo which makes me wonder how the air escapes when filling.
[FONT="]Aux tank Filler pipe goes through the body work to join up with the filler pipe to main tank.[/FONT]
That in floor tank is brilliant! I'd be interested in getting one too if we can get a group buy going.
