Tannin
Senior Member
- Dec 17, 2008
- 209
- Huon Valley Tasmania
- 2007
- Forester
- Manual
My clutch gave out after 187,000k a little while back. Replaced the clutch, then it started slipping again after a few hundred k. Adjusted it, same thing again. Replaced the clutch again (no charge, under warranty), same problem.
Gary (mechanic) long since checked pressures in the master and slave cylinders, which were normal, but the problem keeps coming back. You drive normally for a few hundred k, then you do a longish trip (50k or so) on the highway and the slips are back. Once they come back, it slips all the time from then on, even when cold.
Gary figures that, even though it checks out fine, it must be the master cylinder and he's going to replace it next week. Anyone else had a similar problem?
