Lifted Fozzy recommendations
BlindFromTheSun
Utah
Manual
I am planning on lifting my Fozzy here in the near future. What have you guys found is the easiest and cheapest route?
Welcome,
I have fitted Gorilla HDPE 1 inch lift to both my SG's and are very happy with the outcome.
Here is the link;
https://www.gorillaoffroadcompany.com/product-detail.cfm/prd_key/52
No disrespect to Nachaluva, but you are in the US. You can also donate to the Dian Fossey Gorilla fund !
These are by far the cheapest and given the belting I have given them I can confirm their strength.
I have also fitted to the 2002 SG raised King springs and KYB struts which give an extra 30mm of lift.
For an sf5
- Hdpe 1" spacers, optional: SG struts in rear and 35mm raised springs + rear camber bolts correction.
Sf5 or SG
- 2" spacers and trailing arm block or
-1" hdpe spacers, optional 35mm raised springs and camber bolts.
Where you get them is up to you, but the AUD to USD exchange rate is pretty good if your buying from Aus, our international post rates are pretty good as well.
There other lift options but those are the simplest and most commonly done without issues
