Steam and Coolant everywhere
SuperRu
Admin
Little 5 Points Atlanta
OB Limited 3.6R
CVT
On my short ride home steam starts billowing out the front of the car. I quickly pulled over and there is coolant all over the front of the engine, none on the rear. Oil is clean. I don’t believe I overheated the car. The gauge was normal at all times and it had only been driven about 3 miles at that point. Took about half gallon to refill the overflow and radiator. I drove home slowly the last mile. But it is steaming again and down the same amount of fluid when I pulled into my driveway. Quick visual check showed nothing at first. Steam was coming up both sides of the engine and there is a puddle under car.
Now an hour later it is still slowly dripping from the drivers side front. Near the thermostat/water pump area. It will drip with the radiator cap off then it will stop with it back on. I suspect and hope it is just the water pump seal gone bad. I’m going to let it sit until morning and take a better look at it in the morning. What do you think let go? Can a water pump just blow suddenly? I need to look at what other coolant lines are in that area?
bad / jammed thermostat; split in the bottom radiator hose; blown thermostat gasket - a combination of events.
Sounds like your water pump siezed... that happened to me in an old honda, and it turned out the pressure was just building from temperature... i would get the pump checked asap
:sad: Hope everything is OK. If your oil looks good, hopefully it's just hose, thermostat, or water pump.
Well this actually happened when my radiator cracked on my old 96' Escort, I just drove without coolant for 2 weeks until I got it replaced. Funny enough that little under powered POS never overheated :lol:
It is on the 04 XT.
Just picked up a fresh radiator, antifreeze, conditioner, thermostat and gasket. I love Subaru Bucks. I would up only paying $19 bucks out of pocket. Now if it would just stop raining.
You'll never hear an Aussie say that! Unless you're from Queensland...
How'd you score all that for $19?! Still under warranty? Gotta be happy with that (but not the inconvience).
It is on the 04 XT.
Looks like Atlanta might be a bit wet today.:sad: Hopefully tomorrow you'll get some nice weather.:)
It is on the 04 XT.
My local Subie dealer had never heard of the "conditioner" when I picked up some new coolant recently - maybe its premixed down-under.
