kiwifoz
- Jun 22, 2014
- 287
- Dunedin, NZ
- 1989
- L series
- 5 speed dual-range PT4WD
So at the moment it's not looking good for my car. It's had a bad crunch, has 215000 km and is due for cambelt and needs a clutch. As well, the passenger's Hg is leaking oil and the coolant has dropped noticeably recently. At this point I'm considering not fixing it and instead moving up to an SH or a diesel Vitara.
I have heard of DPF problems with the vitara though and being a French Renault engine I'm unsure of its reliability.
Alternatively, I'd be getting a 2009 SH EJ253 dual range with traction control. Traction control would be great for off-roading, it would certainly help in cases of diagonal wheelspin. I would also seriously consider fitting 1.59 gears and DCCD too and probably standard height King springs in the rear - factory ground clearance is good at 220mm but avoiding a saggy butt is necessary, I've read SH suspension is soft.
I'm also considering a diesel SH and fitting a dual range but that is a bit out of my price range.
