Robbks
- Jan 7, 2014
- 384
- Hobart
- 2010
- Forester 2.0D Premium
- 6 MT
Ok, Just after some opinions/ thoughts and Info.
Long story.
My last car (2006 Liberty H6 with 6MT) had a stuffed centre diff when I bought it, I went to my trusted local mechanic to have it sorted and he put me onto another local tranny specialist (long time and respected box builder for street, race and rally cars)
After a long discussion back then his explaination about the standard VC unit is that it's only designed to provide a precise amount of "drag" on the planetary gears under slippage conditions.
And after a looking at a dismantled one, I agree with his assessment.
Problem with the stock unit is if the seals let go in the VC unit from being overheated, air and visco goop escape, then the plates mash together and effectively lock the two sides of the centre diff together.
His solution is to modify's the stock centre diff to effectively delete the Viscous Coupling with a machined "shim" (about 26mm thick) that is splined to the transfer gear shaft (where the inner hub of the VC coupling would be
And the addition of precisely selected thrust washers on either side place a certain amount of pre-load between the Planetary gears and Housing to retain the "drag" that is needed to provides drive under slippage conditions.
Standard VC is part#5 below
I'm thinking of going this way with my Fozz as the VC is stuffed in this one too.
After another conversation today we believe the effect is sufficient that it provides ~90% as much torque transfer as a standard centre diff would, without the future issues associated with the stock VC failing again.
It's also adjustable by means of changing the washers to provide more or less pre-load on the planetary gears.
however too much pre-load and lots of slippage can cause premature wear of the centre diff gears.
in 99% of cases, I'd probably run with the VDC on anyway, which is going to automatically take car of braking any spinning wheels to provide drive elsewhere,
I figure the only time I wouldn't would be in mud or on sand where you want the wheels to keep spinning to maintain momentum and grip onto anything they can.
Just wanting others opinions and thoughts on a different piece of gear than is usually on offer.
Long story.
