exact rates for King Springs?
Robbks
Hobart
Forester 2.0D Premium
6 MT
Is anyone able to shed light on the exact rates for King Springs, std height for the SH
I've searched just about everywhere and can't find teh info.
even Kings don;t list it
send an email to primitive racing they should know.
Almost a week an no response from them,
Local suppliers have none of that info in the catalogues or through their wholesalers
Sounds right - my Kings extra-HD are 250 lb/In (corrected)
so they compress 250 feet for every pound..... (ft/lb)
think we need to establish some units for measurement.
I reckon it's more likely lb/In
250lb/in = 9.84lb/mm = 4.46kg/mm (same as pedders)
but I suspect the SH would be stiffer than the SG
There are certainly some very odd combinations of units in common use.
It took me a while, but I finally figured out that gas strut pressures are measured in Newton centimetres^2! :confused: :shrug:
Directly from Kings (Finally)
Front KSFS-55 290lb/In = 5.2kg/mm
Rear KSRS-56 250lb/In = 4.46kg/mm
KSRS-57 250lb/In
Directly from Pedders
Front 230022 4.46kg/mm
Rear 230023 4.32kg/mm
Given the slightly higher average rate of the Kings and their newer progressive rate design, I might actually give them a go.
I've not liked Kings in the past due to harshness, but that's a good 6+ years ago and things might have changed.
And for over $100 cheaper a set than the Pedders for springs alone, it's hard to go past them.
Seems this is about the best deal around for a complete set with KYB's too
https://www.ebay.com.au/itm/SUBARU-...=AU_Car_Parts_Accessories&hash=item4d0dad0af7
