subaru-offroad
Howdy again.
I just got done taking a ride and saw a shell gas station offering nitrogen enriched fuel. I did some research about it, and decided to write an article about it. After in depth research, it turns out it contains 5x epa required amount of detergent, and more than double top tier gasoline standard for detergent. Plus nitrogen is an inert gas used to prevent fire in space shuttle, oil rigs, aircraft, and also in your tires. So how on earth is this fire resistant material going to help my engine?
Is this amount of detergent good or bad? Anyone used it? It sounds great because it fights gunk and carbon, but is diluting my gasoline with more cleaner going to affect my immediate performance ust to save a couple of $$$ later?
It sounds good, but it also sounds like a way for gasoline companies to dilute and make more $$ per gal pumped out of the earth.
what do you think? nitrogen gas a good intention, or bad?
UPDATE! CONTAINS AMIDES THAT DESTROY PLASTIC, RUBBER, AND PROMOTE FUNGI GROWTH.
DO NOT USE THIS FUEL.
