Ratbag
- Jan 1, 2012
- 7,480
- Bayside, Melbourne, Vic
- MY06, MY10
- Forester SG & SH
- 5MT/DR & 4EAT Sports
Well, Folks
Over the last 4-5 days I have finally had the serendipitous combination of the right weather and reasonably conducive health required to seal around the base of SWMBO's kiln shed where the crappy thing joins the crappily laid concrete slab it sits on.
Every time it has rained since it was done last Feb-Apr, it has leaked like a bloody sieve.
Our lovely plumber, electrician and gas plumber each fixed some of the really lousy (Australian) "design" that it represented.
I have needed to research how best to seal where the steel fails to accurately meet the concrete.
The weather also needed to be bone dry for about a week prior to starting the job, and for the duration. I even considered using Dunlop Tile-All Plus, which will even adhere and set under pool water. However, at nearly $40 a tube, this was looking to be prohibitively expensive. I have used it to glue water line tiles back on in our pool. Sticks like baby poo to a nappy ...
Finally settled on Sikaflex-11FC. It is a polyurethane based adhesive sealant.
This stuff also sticks like baby poo, but requires a clean, firm, dry substrate. It also costs a bomb - $18 a tube. Have used 4.5 tubes to finish the main job.
The Sikaflex comes in a small variety of colours, and will glue and seal most materials except the usual suspects of PE and some other plastics.
It is exceptionally tough once properly set (about 3 days IME). I have put a standard bog gun tube nozzle down on a half brick after using it to pierce the internal seal of the Sikaflex tube with. I can lift the half brick by the old nozzle.
Cutting off the dags with an Olfa knife shows how tough it is. More so than normal silicon-based products.
The part of the shed that had the worst leaks was the door sill for the double doors. It had a gap of around 5+ mm between the bottom of the sill and the concrete. I have filled this gap and glued 25x20x1.6 mm aluminium angle on each side of this, with the legs facing away from the sill. I did the outside part some days ago, then fitted the internal piece today. When the Sikaflex has set a bit, I will rivet these bits to the door sill. These will provide the mechanical strength so that the adhesive/sealant only has to seal the sill rather than holding it against rotational forces if someone stands on it (as one does ... ). It also makes this part some 60 mm wide, giving plenty of surface area for adhesion, and a stable platform to resist twisting motions.
Not sure how suitable this stuff would be for automotive use, but it seems a better choice than silicone, which can tend to rot steel.
