Real quick, and most likely real easy question. I'm installing a dual battery system. Main battery is an Optima red top. Second battery will most likely be an Optima blue top deep cycle. I've been told that I can directly wire the two batteries together (neg to neg, positive to positive). Makes sense to me, and would install a 100 amp fuse as well. Here's the question. Do I need to run the negative terminals together, or can I ground the second battery to the chassis in the same manner as the main battery? I'm not going to worry about charging the batteries separately since they will both be connected to the alternator. The batteries will be wired in parallel (doing so to get the bump in amperage) using 4 gauge wiring.
Besides the grounding question, do any of you see a problem with this setup?
What are you trying to achieve? Are you adding a second battery for car audio or for a winch/fridge, etc?
I ask because how you arrange the batteries will really determine the answer.
Yes, you can just run the 2 batteries in parallel, effectively creating one big battery, however you will need to use two new batteries of the same kind, ie 2 deep cycle agm, or 2 lead acid batteries. The reason is that the 2 batteries won't be charged correctly. You can and should add an isolator, meaning that the batteries are charged and power drawn from independently of one another. You can find isolator's that combine when the vehicle is first started so that the engine receive's the maximum voltage and amperage possible.
The benefit of an isolator is that you can run accessories to each battery and each battery being on it's own circuit won't get over charged by the alternator. You can leave the stock battery stock, and then put all of your accessories on the second battery, so that if you pull too much amperage with the accessories, you can still start and run the engine and basic functions of the car.
I was looking into a
Hellroaring Isolator, and spoke with the owner several times. He suggests putting all the accessories, lights, winches, etc on the primary battery, then using the backup battery for starting the car. But to me that seems backwards, it's also backwards how it's recommended on other online 4x4 forums, such as pirate 4x4 and expedition portal.
Another benefit of the isolator is that you can run different batteries, like you had mentioned, wanting to run a normal battery as well as a deep cycle. I will say with your grounds, while you can run them both to the same ground, you don't need to. Just grind back to bare metal and insert a bolt.
As well if it's easier for you to mount a battery in the trunk, or wherever, an agm battery is sealed and won't off gas like a normal battery, and you could get the added benefit of better weight distribution over the axles.
If you have any more questions on the subject I can find good links to the subject that I have bookmarked on pirate 4x4 and the such.
Andrew
