kiwifoz
- Jun 22, 2014
- 287
- Dunedin, NZ
- 1989
- L series
- 5 speed dual-range PT4WD
So having done a bit of reading on various Subaru forums, and because NZ 4wd tracks almost invariably involve crossing rivers, I wanted to move the ECU in my Forester.
The stock location for all Forester ECUs (except 2.0 SF models) is under a steel panel in the passenger's footwell. This is easily accessed by popping off the sill kick panel and pulling up the carpet a bit.
Then you just undo a couple of bolts and the ECU comes out. Before unplugging it I'd recommend disconnecting the battery.
To remove the glovebox, simply open it, empty out your stuff and undo the seven screws. It'll pretty much fall off then.
I looked around to try and fit the ECU behind the glovebox but there just wasn't enough space. So I grabbed my jigsaw and went to town.
Popped off the owner's manual holder, and cut a rectangular hole in the back of the glovebox for the rear of the ECU to poke through.
Mount the ECU using cable ties through the holes for the owner's manual shelf (you could drill holes and bolt if you want).
One thing you will need to do (if your car has cruise control) is undo the two bolts holding the module on and let it fall down - this is necessary to route the ECU cabling.
You can then cable tie it back up under the dash, I attached it to the ECU wiring bundle.
Basically, this mod will stop you drowning your ECU if you get water in the car - it increases the wading depth by around 20cm (airbag module is under stereo).
Finished product:
You don't actually lose any glovebox space as the ECU takes up around the same volume as the owner's manual shelf.
Disclaimer - this is likely to void any warranty you may have, and proceed at your own risk as you could damage your ECU, wiring etc.
Finished product:
