Venom
- Jun 8, 2009
- 632
Thought i'd do a separate thread to my car build because I may not follow through but some information may come out of this which others may find useful.
My suspension travel with BG9 outback shocks and 50mm strut tops on the car. Measurements to top of wheel arch.
On the ground (resting height): 460mm front and rear.
Fully compressed: 420mm front 385mm rear.
Full droop/extension: 545mm front 550mm rear.
All measurements are height from centre of castellan nut to the top of the wheel arches directly above.
145mm total travel in the front and 165mm in the rear. 40mm compression in the front and 75mm in the rear. Up front at full compression there is 60mm to the top of the wheel arch.
Pulled a set of S/H shocks from a car at Jolly's.
Measuring these from the base of the shock body to the end of the second step after the thread on the piston(?). This is without bump stops.
Front: Compressed length 400mm, extended 550mm. 150mm of travel, the body of the shock (base to weld at top) 355mm.
Rear: 475mm compressed length, extended 685mm, 205mm measured travel. Shock body 420mm.
Now because I have 50mm strut tops whose length I want to incorporate into the shock, it should just be a matter of adding 50mm to the above measurements to give me a baseline to work from.
Front 450mm compressed, 600mm extended.
Rear 525mm compressed, 625mm extended.
Objectives: gain compression, extension (assuming shock is not limiting factor), maintain current ride height.
BG5 koni insert stats: Need info on the fronts. Rears body length 400mm, min length 433mm, max length 675mm, 242mm travel.
BG5 Konis are out of production? Not listed on the Koni website but I can find part numbers.
More to come...
More to come...
