Ratbag
- Jan 1, 2012
- 7,487
- Bayside, Melbourne, Vic
- MY06, MY10
- Forester SG & SH
- 5MT/DR & 4EAT Sports
Gidday Folks
I cannot believe this, but here it is ...
Roo2 has a "genuine" Subaru towbar. It has "SUBARU" and the compliance information stamped on it. It was fitted prior to delivery.
This afternoon, I spent over 2 hours investigating the non-standard wiring in my attempts to install the reversing light circuit ... This is covered by regulations that prescribe the wiring for small trailers.
The 7 pin connector plug on the rear of the car looks completely Kosher when opened. It just doesn't give the correct voltages at the various pins.
I then started to investigate the internal wiring of the car.
For starters: there is actually a large rubber grommet/plug behind the D/S rear light that is about 18" higher than the one that has been used for the trailer plug wiring at the bottom of the spare wheel well. This has to be the height of stupidity when there is a grommet provided, seemingly for this very purpose!
I pulled the actual trailer wiring socket apart, and it had the appropriate 7 colour coded wires running in to it, albeit some were loose.
Feeling the insulation taped connections, I could tell that there were joins in the wiring loom on the trailer connector side.
As I stripped off the layers of insulation tape surrounding the internal trailer wiring plug that is part of the car's wiring loom, I found more and more oddities.
Firstly, two of the seven wires had been taped back. This is a tad odd, I thought. I have 7 wires at the socket ... WTH is going on here?
Then I found that there were two whites and two browns on the socket side of the plug into the car loom. This is really bloody odd ...
[EDIT]
These two white wires and the two brown wires were connected to each other inside the trailer connector wiring loom, which has a Subaru part number on it ...
[end edit]
Out with my dissecting scissors, and started carefully cutting off the multiple layers of insulation tape. All of this looked perfectly original.
Out with the multimeter. That's odd. One wire that is available (but not connected to the trailer socket) has a constant 12V across it even with the ignition completely switched off.
[EDIT]
Photos of the car wiring loom and connector:
Close-up of the car loom female connection plug:
This is the tail plug of the wiring to the trailer socket. Note the two wires that were taped back - BLACK is for reversing lights; BLUE is for electric brakes. Both these are present at the trailer connection socket on the rear of the car ...
[end edit]
{Re-edited to reinsert photos deleted by forum software upgrades.}
to be continued ...
[EDIT]
[end edit]
[EDIT]
[end edit]
to be continued ...
