svynx
- Sep 11, 2014
- 28
- Dover, pa
- looking around
- unsure on what
- i want to lift
I just purchased a 2003 Impreza TS wagon. It already is lifted on 04 FXT struts and springs. Rear trailing arm bracket switched to recenter the wheels. It currently has 15" wheels, with a no name brand tire (extremely loud, even at 25mph). Still stock size overall, so no issues driving. I've driven a similar setup that had the same gearing, but 215/70/16 tires. Needless to say, low end torque disappeared, and acceleration was non existent. So, after some research, I found that the TS has a 3.9 final drive. If I were to swap out the ring and pinion gear with that of a 4.44 (and the rear diff), increase the tire size to something in the 27" diameter range, the feel of the car will be back to normal.
I don't know if this is possible or not. I would switch to a FXT transmission, but the clutch type is wrong. Anyone try something like this?
