oh, and did you use 2 camber bolts up front per strut?
I would strongly recommend against that lol. Unless you mod the strut/hub to take a second factory camber bolt, even then they still break occasionally
https://www.dirtyimpreza.com/forums/showthread.php?6365-Camber-Bolt-FAQ-and-Tutorial
I'm running SPC 14mm camber bolts in the front lower/rear upper positions. No problems after 2 years, YRMV.
If you do fit a second camber bolt, adjust it to maximum and use the factory bolt to fine tune.
Please and thank you. (no offence taken, looks like we could use a camber bolt thread)Mods, can you pull this out of EJs build thread?
