PauSum
- Aug 1, 2008
- 321
- Perth Australia
- 2005 and 2015
- Forester and Outback
- 5 speed manual and 6 speed CVT
Gidday PS
I am having my GB and diff oil changed next week (at 110,000 kms). I am certain that Ross will be putting a Shell FS oil in them. He reckons that it will never have to be done again, barring getting water or other crap in either of them.
He also reckons that these FS GB/Diff oils should last the life of the car under normal circumstances. The only reason I'm having mine changed is that I bought the car s/h, and do not know what might or could have happened to it before I bought it. I also intend to tow my trailer about 5,000-6,000 kms over the next 3 moths or so.
It was a while back but I used Castrol Syntrax which did help gear changes to be smoother. Cannot comment on the others as I have not used them.
If you are going to DIY you will also need a very rare Torx 70 (I think).
This bit is not found in any of the usual auto stores like Repco, SCA etc
Thank you Ratbag,
I didn't see shell at all in the auto shops I went to, might have another look.
The reason why I wanted to change them is I can feel the car having some "pulses" moving when (usually) climbing up slopes. This has happened for a while. I just had the HG done last month and the dealer swore to me that the clutch was ok - although they agreed that it was a bit hard. I looked around and think maybe replacing the GB oil hoping to elimiate this as a potential problem as the car has just done 175000km; although I can still change gears with no problem
and the cost of a full GB rebuild is what spooks me. I reckon $100-200 now is very cheap insurance.
After that, I will probably never consider doing it again, unless something nasty happens and either of them get water in them.
Shell's complete product guide is available as a PDF here:
https://s02.static-shell.com/conten...data-guide/product-data-guidecomplete2012.pdf
You need to go to around page 42 ...
If you are having pulsing I doubt it is you gearbox. and if the clutch is getting hard that may be becoming an issue- Mine got harder and the new one is significantly lighter than the old.
Before dropping the oil buy a new crush washer from subaru. Won't seal without a new one and changing the box oil twice sucks. pretty sure the part no. is 11126AA000
drain plug is indeed a ***** to remove, i usually do it under the car (without it jacked up) with a breaker bar and shortest extension that'll fit. Then proceed to swear when i crack my knuckles when it lets go.
PauSum
That is defiantly the right plug. Depending on who has been doing your servicing it may have never been taken out. If that is the case it will be TIGHT. Another trick would be to put some heat into it you will need an gas torch. I have seen those small kitchen blow torches used.
I would do it on the ground heat it up so that you can touch it for 2-3 second and wedge something under the bit/breaker. Add a cheeter bar to the breaker bar and then lean on it
