^ Hahahaha, Oscar :biggrin:.
My main workstation is nearly 7 y.o. and my laptop has celebrated its tenth birthday. Both still do what they are required to do. Generally, they do this faster than the latest and greatest because I know how to keep them in top shape, both logically and physically. So do all our other computers, some of which are (much) older than my laptop ... :ebiggrin:
The best keyboard in the house is a 1988 IBM amphitheatre ergonomic keyboard that uses magnetic reed switches in the keys. Beautiful to use. My wife won't let me use it on my main w/s because the keys are too noisy when I'm typing fast at night. Our bedroom is right next to my study.
Perhaps you don't keep your various computers long enough for them to fail! :lol:.
Since being given the laptop by a client (an IBM R50, made in 2004), I have replaced the HDD because it was far too small (36 -> 320 GB) and chucked a whole lot of decent RAM into it (256 MB -> 2 GB).
I expected the RAM to speed it up significantly - it did indeed!
What I didn't expect was that replacing the OEM (Hitachi) HDD with a WD one (IIRC) would double the speed of the computer running things like Photoshop CS5 and Bridge - half the loading time for both of them. Both are 5,400 rpm drives, but the larger one has a dirty great cache in its IDE controller, the OEM one didn't have one at all. Just amazing the difference that made.
The laptop also has shock and movement detection that automatically does an emergency retract of the r/w heads in the HDD. This works ...
Just recently, I bought a new battery (Sanyo, same as the OEM one, and same capacity), as the original OEM battery had dropped to about ~22% of its design capacity (~71 W/h). After getting the new one, I savagely reconditioned the original one, and managed to get it back to around 38% of its design capacity. It will run the lappy for about 1.5-2 hours now. The new one will run it at full speed for about 5.5-6.5 hours of continuous use. Not bad for an old clunker!
BTW, if I hit a burglar with the lappy, I would probably be charged with GBH or murder, and I have no doubt that the laptop would still work! I can pick it up by the top/centre of the screen and nothing even complains. The screen hinges are solid steel, or some similar ferro-magnetic material ... Built like the proverbial brick outhouse ... :biggrin: :rotfl:.
Mind you, it cost around $4,500 new ... Top shelf stuff; not cheap nasty plastic crap. I expect it to serve me well for quite some years to come.
