NOALSY
- Jun 23, 2014
- 5
- GoldCoast
- 1991
- L series
- manual, 5 speed, dual range
hey guys, Its been awhile since my first introduction post so i thought i should put up an update on the 91 L series project.
so as i mentioned earlier my clutch was shot so i decided to replace it my self. instead of removing the engine i removed the transmission for a couple of reasons. Any way the removal was pretty smooth with the exception of the spigot bearing, that was a PITA! however whilst removing the trans the 4wd linkage U joint got mangled a bit but i fixed it up. (it wasn't bent or anything)
so i replaced the pressure plate, thrust bearing, spigot bearing, friction plate and shifter linkage bushings. an Exedy HD clutch kit was installed
after it was all back together i noticed that the 4wd lever seems to be jammed in 4wd high, it doesnt want to budge an inch even after reversing. there's no gravel or lose surfaces around me to try to chirp it either.
It wasn't jammed when i removed it. Its pretty darn unusual
