technogeekery
Hi guys - have read up on this, and think I understand it, but would like to get some more expert opinions.
We are thinking of adding a 3-way fridge to our camping setup. We prefer to find somewhere really remote, and then camp there for 5-10 days at a time, so 3-way is probably the go for us, avoids all the 2nd battery and solar faffing about and expense. Have pretty much settled on a Dometic F400 fridge freezer, which seems to have great reputation for being unkillable and doing what it says on the box.
We don't plan to use it on 12V much, just while we are on the road, but we would like to run it in the car while we are travelling - some of the transport legs are one or two days of 10-hour driving. Like most 3-way fridges, it won't work on the standard cigarette-lighter outlet in the back of the Forester - voltage drop is quite high, and this thing draws 10A+ continuously, and the wiring is not thick enough to cope, apparently. Waeco supply a 12v plug, but you have to get it wired directly to the battery with heavy duty cable.
I'm keen to try this myself, as a 12V learning exercise and to save a bit of money (fridges = exxy). It sounds simple enough - I'll measure it up, but about 6-7m of 8WG cable, get it all routed up through firewall and under trim to back of car. Fit 20A in-line fuse holder & fuse near the battery end, crimp on a couple of ring connectors on the battery end, an anderson plug on the other end, and then make up a short cable with a bit of excess 8WG with an Anderson on one side, and the Waeco connector on the other, as the fridge connector.
Anything else? Any traps for young players? Do I need to build in some kind of auto-sensing switch (relay?) to turn the fridge off when the car is off? I'd like to do that if I could, as it will kill the car dead in a couple of hours if I leave it running in the car by mistake - so any suggestions of what type of relay is appropriate?
Thanks
Thanks
