So after bragging about the ABR Sidewinder fridge and battery box I bought it starts to go to sh1t.....
I've noticed that of late the Isolator built in to the batt box has been chattering. I read in the instructions for the box this usually means that the alternator voltage is dropping below 14v. The anderson plug at the back of the car is actually wired via a incar Redarc dual charge isolator so I'm going to wire round it and see if it stops that.
In hand with that.... the fridge should give an initial 'beep' and then display the current temp then after a few minutes the main fridge fan kicks in and its starts to cool.
At the moment the fridge does all except the fan does not come on and the fridge never cools..... not really any good at all. I've run the fridge using the 240v power supply that comes with it and it runs fine.
I have tested the fridge off the battery box and straight off the in-car 12v cigy sockets. Same results. I e-mailed the maker of the box and fridge and he said if it runs fine on 240v then its fine..... its not getting the required 12v on start up....
I'm no jet with power.... I dont see how it can get some power but not enough tot do the job..... any clues...????
Scott
Scott
