MiddleAgeSubie
- Dec 15, 2013
- 990
- AZ
- 2018 / 2008
- 4Runner / Tribeca
- 5EAT
Hi all,
A few threads over at subaruoutback.org discussed recently tire size upgrades for 2010-14 OBs.
Somebody posted that 235-65s should fit "snugly." But I do not remember anybody actually sharing experiences with such tires.
Here is an approximate tire size diameter comparison (apparently exact measurements vary by brand):
Stock size, 225-60-17 at 27.63 (diameter)
235-60-17 at 28.1
225-65-17 at 28.52
235-65-17 at 29.03 This means a significant ground clearance gain.
I am extremely interested in actual experiences with 235-65-17s.
Why?
Struggling with a decision about how to remedy the occasional need for extra ground clearance while keeping the car as close to stock as possible, I have not yet pulled the trigger on a planned 0.5" lift. Instead, I am now thinking about purchasing a set of used 235-65-17s to mount twice a year. Indeed, since I will have enough Subaru rewards dollars before I need the tires, the cheapest option for me may actually be to negotiate a set of new ones from my dealer (I cannot pay hundreds of actual dollars for such things).
As you can easily understand, theoretically the 235-65s should give me the best of both worlds--about a 0.7 lift with no mods to the vehicle--easily done, easily undone after the trip. Does this sound like a fine solution to those of you with experience in using non-stock sized tires?
Obviously, trimming of the mud flaps on the front pair will be necessary.
Also, is it a good idea to mount the occasional-use 235-65s on steel wheels?
Thoughts?
Thanks
235-60-17 at 28.1
225-65-17 at 28.52
Why?
Thoughts?
Thanks
