Rizzo03
Ok dig, I'm back again for some truthyness
I have a hum in the rear of my Baja and it does not change if I turn or change lanes, But damned if it isn't a bearing noise.
Having done the rear brakes I checked the outer actual wheel bearings and they're both fine.
Today I checked the inner bearing at the rear differential. I can move the half shaft up and down, Shouldn't it not do that?
Does this mean that, That bearing is toast ?
If that's so then how come I can't find one anywhere ?
Thanks guys.
If it would help I can shoot a video of the movement.
(The Baja is based of the 00-04 Legacy and Outback if that helps.)
Thanks guys.
