PigSti
Guest
Any one using the iCom 400Pro UHF?
I've got the mods to make program cable and increase range and power, plus allow you to access the extra HAM channels.
Any stories to share?
:ebiggrin:
The Australian IC-400PRO UHF CB comes pre-programmed with 80 UHF CB Channels + 48 user receive channels
Icom Australia 3 Year Warranty
Commercial Specification
Designed for the most extreme Australian conditions.
Die-cast aluminium chassis and heavy-duty heat sink, impact resistant polycarbonate front panel incorporating 4W speaker for crisp clear audio, even in high noise environments.
Industrial Grade Condenser Microphone.
Meets U.S Military Specification 810 (C, D, E & F) for Dust, shock and vibration.
Super sensitive wide band receiver.
The IC-400PRO is also compatible and fully approved for use on Licensed Land Mobile Services at 25W within the 450-500MHz band * at 12.5 or 25kHz when re-configured by an Authorised Icom Radio Dealer. (* ACA Licensed Users only)
Unique Repeater Scan
Our Unique Repeater Search function finds available repeater stations while you are travelling.
Open/ Group/ Priority Scan
Scan all or only tagged channels, while also monitoring your priority channel.
Silent Stand-By
Listen only to your own group!
Up to 51 user selectable CTCSS group codes are available for silent stand-by operation. DTCS is also available in private channels.
SelCall (Selective Calling)
Hear only the calls intended for you and see who called with Selcall !
The IC-400PRO comes with all popular CB and commercial 5-Tone Selcall formats, along with user selectable ID number set up. The last 10 caller ID's are stored for easy recall and up to 28 numbers can be pre-programmed with name tags for easy reference (software required).
Smart Ring and Automatic Transponder
Acknowledges if other Icom IC-400PRO / IC-40Jr / IC-4088S transceivers receive your call or are within rage.
(* This feature is not available until user-activate it by PC software.)
Easy to use and install
General Specifications
- Touch pad controls and rotary volume dial
- Backlit LCD with 8 character alpha display and status icons
- Comprehensive user and operation manual
- Compact and light with front facing speaker and quality mounting kit for dash, roof or console mounting
- Optional DIN size kit, for in-dash installation
Transmitter Specifications
- Frequency Coverage:
- CB channel: 476.425 -477.400 MHz
- Private channel: 450.000 - 500.000 MHz
- Number of Channels:
- CB channel: 80 channels
- Private channel: 48 channels
- Channel Spacing:
- CB Channel: 12.5khz
- Private Channel: 12.5/25kHz
- Power Supply Voltage Requirements: 13.8V DC
- Current Drain (at 13.8V DC):
- Transmit [CB (5W)]: 4.0A
- Transmit [Private (25W)]: 7.0A
- Receive (max. audio): 1200mA
- Receive (Stand-by): 300mA
- Operating Temperature Range: -10°C to +60°C
- Antenna impedance: 50 ohms (SO-239)
- Frequency Stability: ±2.5ppm
- Dimensions: 150(W) x 40(H) x 117.5(D) mm
- Weight: 800 g
Receiver Specifications
- Output Power (at 13.8 V DC):
- CB channel: 5W, 1W (selectable)
- Private channel: 25W, 5W, 1W (selectable)
- Max. freq. deviation: ±5.0/2.5kHz (wide/nar)
- Spurious Emissions: -30 dBm
- Adjacent channel power: -22/-16dBm (wide/nar)
- FM Hum and Noise: 46/40 dB typ. (wide/nar)
- Mic. impedance: 600 ohms (8-pin modular)
- Sensitivity: 0.25µV for 12 dB SINAD (typical)
- Squelch Sensitivity: 0.25µV typical (at threshold)
- Adjacent Channel Selectivity: 73/65 dB (wide/nar)
- Spurious Response: 75 dB
- Intermodulation: 70 dB
- Audio Output Power: 4W typical at 10% distortion with a 4 ohms load
- Hum and Noise: 45/40 dB ohms typical (wide/nar)
- Ext. SP connector: 2-connector 3.5mm/ 4 ohms
:ebiggrin:
