PigSti
Guest
I've heard that lift kits can shorten the life of CV joints rather dramatically. Has any one experienced this?
If you increase the angle on your CV's you just need to get used to the fact that you will need to replace boots more often. check them regularly as if you replace them as soon as they split you minimise the chance of damaging the actualy joint.
I seem to go through front boots every 50k or so. i just replace them before every big trip I do if they look at all tired.
