ID from a pic like that is fraught with danger, as is handling it unless you are
very sure you know what you're doing...but I'm pretty sure thats a Diamond Python, going by the thick body, colouration & your location...
Check out post 4, also 14:
https://www.australianreptileforum.com/arf/f109/show-us-your-diamonds-12219/
Also:
https://www.gumtree.com.au/s-ad/melbourne-region/reptiles-amphibians/diamond-python-/1024592185
Remember, these are much nicer coloured as they are bred for the bright yellow.
If you want to handle it, find a branch about 4' long with a fork at the end, pin its head to the ground & hold it firmly behind the head. Remember, pythons are powerful snakes & he
WILL wrap coils around you...you may need help to remove them. Although non-venomous, they can have a nasty bite with their 128 needle sharp, backwards curved teeth, & can also carry Salmonella.
So...use caution! :rotfl:
Discalimer: You should be
VERY sure of the snakes identification & also be competent in its handling before attempting to handle a wild snake. Or any reptile for that matter as most can give a nasty bite &/or carry Salmonella. Also, all reptiles are protected & taking them from the wild is not only reckless, selfish & ecologically very damaging its also illegal.
Best advice is take only photos :iconwink:
