silver
- Jul 10, 2008
- 1,018
- Tathra, Far South Coast, NSW
- 2005
- Forester
- Manual
Well i thought i would have a go installing the Bendix 4WD front brake pads i got off Gumtree for $42.50.
I was a bit nervous about doing it as i have never done this but figured the worst that could happen was i would have to get a mobile mechanic to come and fix it up if i botched it.
I bought some Permatex Ultra Disc Brake Caliper Lube in sachets from Superchina for $11.95 the other day (i joined the Superchina club online for $5.00 which gave you $10 off the first order).
I read a few things here and watched a few Youtube clips and got to work.
WELL....bugger me if that's not a simple job!!!!
I didn't do anything complicated...just had a look at the disc,which was fine,only undid the bottom nut and checked the slide was moving freely and pulled the pads off and got a bit of a surprise!!
I've done 142,712klms,some towing a camper trailer,some towing a caravan,a boat,living in stop start traffic on the Gold Coast, highway miles and off road stuff.
The OEM pads have almost as much left on them as the new ones i WAS going to put in. I figured there was no point yet.
The surface area of the Bendix pads is not quite as large as the OEM ones but i suppose it's more to do with the materials used. I reckon there is around 7-8% difference.
I also checked the back rear ones just for a comparison and they are the same as the front.
At this rate i would get 250,000klms minimum out of the OEM ones.
I don't know if brake material degrades over time but i assume it probably would so i will do the job in the next few months anyway just to see if there is an improvement in the braking.
I got a quote for the rear pads of an ARB shop in town and he quoted $85 for the set. This was for Bendix GCT (or GCP) and the front being the 4WD pads i'm guessing would have been ...say....$100.
Subaru wanted $165 F and $130 R so $295 against $185 for Bendix.
They also wanted $195 to fit them F&R (thats all up,not for each end).
So if you took it to Subaru the all up cost would be $490. Do it yourself..$185 plus $11.95 for lube..call it $200.
Subaru is saying,roughly, 2 hours for fitting the pads which is fairly outrageous considering they are pros and have hoists and rattle guns etc.
I could easy do it myself in that time. I would think an organised workshop with 2 people working together would take 20 mins to finish the job.
Anyway,glad i did have a go and very surprised how simple it was.
MY CLEANING UP TIP......don't worry about getting expensive stuff for cleaning your hands....just use powdered laundry detergent. The powder works better than liquid and i have done this for years. It might surprise you how well it works.
