fayfam,
Did this 6 weeks ago, Below is what I ordered. Job took about 5 hours including valve cover gaskets and and Oil change and new leads and coolant.
I used a forward shipper as Amazon would not ship the water pump to Australia. I have read that the gates pump isn't so flash so wanted the asisn. The one I got looks great good casting and finish - I am fairly sure the one I ordered will not fit your car- mine had the thermostat exit facing the radiator not the ground and has one bypass line
You will need to check the part numbers particularly the water pump there is a part change around 2006
The gates kit is excellent - the idlers and the tensioner have the same markings as the ones removed (manufacturer and part number was IDENTICAL).
Came in at about $370 AUD in the end but the exchange rate at the time was $1.05 US and it has come back a bit since then. If I was doing it again I would probably order the gates kit with water pump of fleebay and if I didn’t like the look of the water pump get a factory one I was quoted about $135 for genuine in Australia - then sell the gates one.
While I was at it I also replaced some of the spring clips on the radiator hoses with the screw type (only the ones that are hard to get at (I was being cheep)
DescriptionUnit priceQtyAmount
www.amazon.com-Beck Arnley 036-1860 Valve Cover Gasket Set - Beck Arnley$32.481$32.48 -Gates TCK304 Timing Belt Component Kit - Gates$168.241$168.24 -Aisin WPF-025 Engine Water Pump - Aisin$57.201$57.20 International Shipping-Priority Mail @ 17.00 lb(s) Items are too large for a prepaid large box.$105.731$105.73 Postal Insurance$5.901$5.90 Ship to Oz Fee$33.261$33.26 Subtotal$402.81 [COLOR=#333333 !important]
Total [/color]$402.81 USDCharge will appear on your credit card statement as PAYPAL *SHIP TO OZPayment sent to Ship to Oz
Crazydave
