Looks good, NL :ebiggrin: :biggrin:
Hope you have enough vertical space to fix the folding flap up against the upper part of the barrier ...
. I'm sure you would have measured that first though ...
Now that you have all that experience, maybe you could help me fit my barrier in Roo2? Or at least give me some tips.
I have also thought of hinging it in the middle, so that the P/S side half can fold out of the way in an L shape back into the cargo area (for sleeping in the car; sticking long stuff in the P/S, etc).
Another thought is to have extendable "legs" that allow it to be pushed forwards up against the front seats with the rear seats folded down.
How is yours fixed into the car shell? I have the barrier, but no mounting points or hand nuts. SWMBO's car has the mounting points and hand nuts, but no barrier (different size ... ).
I was thinking of using the tie down bolts behind the back seats for the bottom, and aluminium struts to the baby capsule mounting points at the rear of the roof.
The barrier is only rated to 60 kgs, so almost anything will hold it in place IMHO. It would appear that even if the barrier were only anchored at the bottom, and held in place vertically by the seats (with seat belts plugged in), I don't reckon it would go anywhere in a hurry, even in a fairly serious prang.
Perhaps it would be a good idea to use a bit longer high tensile bolts on the existing anchorage points?
