NachaLuva
Product Developer
One of my front control arm rear bushes has been leaking for bout 18mths now, just recently the other one started too. I have since found out not adjusting them after installing raised springs has killed them!
So I got these:
Control Arm Rear Bush (Castor)- SuperPro
They even come in Subaru blue!
Only now I need some help installing them. I should be right putting them in by using a vice to press them in. I was going to try using a vice to push the old ones out using either sockets (dont think mine are big enough) or 2 sizes of pipe, one the size of the housing, the other the size of the sleeve.
Will this be hard? Any better way of doing it? Also, does anyone know what size pipe I would have to use?
I might also try using a heat gun to heat up the alloy housing to expand it slightly...
So I got these:
