Gidday Folks
Leaving aside the blatantly obvious statement that having the correct tyres for the make and model of vehicle for the specific conditions is a good idea, this is the greatest load of frogsh!t I have read in many a long year ...
Having driven all kinds of vehicles - RWD, FWD, 4WD, AWD; cars, light trucks, heavy trucks (I still hold a National Heavy Vehicle licence), 2WD & 4WD tractors - for well in excess of 1,000,000 miles in all kinds of conditions on all kinds of tyres - road tyres, racing tyres, snow tyres, directional bar lugs, full bar lugs, off-road tyres of many different construction and tread designs, my experience is utterly different.
I had my AWD 1993 Impreza for nearly 18 years and 234,000 kms. With identical make and model of tyres on both it and our Camry (same age), I could easily tell the difference in directional and vehicle stability at 60 km/h on dry, hot-mix bitumen suburban roads, let alone any others you can think of ...
Now, I would perhaps put that down to my sensitivity to vehicles from both my wide experience and natural affiliation with things mechanical, were it not for the fact that my dear lady wife who has neither of the above could also tell the difference under those (ideal) conditions, let alone in the wet, etc.
On a far more technical basis, one major reason why this person is so wrong is that the driving wheels of a car with 2WD are (usually) far better located by the suspension system than the other two wheels. FWD cars tend to have relatively basic suspension at the rear (some even have solid rear axles ... ), and this suspension system allows those wheels to move in a more "dynamic" way - i.e. they do not maintain absolute alignment with the front wheels. This was the case even in our dear old Camry which had relatively decent rear suspension, utilising MacPherson struts and other locating arms - by no means the worst system available.
With any reasonably decently designed AWD vehicle, all 4 wheels are rigidly located by necessity to counteract the tractive forces applied to all driven wheels.
For the same reason/s, an AWD passenger type vehicle has to be more rigid in its body shell than its 2WD counterpart to enable accurate alignment of the wheels under all conditions.
Both of the above make for greater directional and general vehicle stability. That was the case with my Impreza, even 20 years ago with "stability control" being limited to split system braking ... 18 years later, I could still throw this vehicle into a marked 50 km/h corner at just over 100 km/h; a corner that one could take reasonably safely in the Camry at 75-80 km/h ...
The RWD Jensen Interceptor I drove was very similar in handling to the E-Type Jaguar of the times (late 1960s), i.e. very urbane, and excellent. The Jensen Interceptor ff I drove was in a whole different league. It had the positively agricultural Ferguson 4WD system (literally adapted from that of a 4WD tractor ... ).
Perhaps the writer's experience was testing that Ford Explorer (??) that was fitted with the Firestone tyres that managed to kill some hundreds of people in roll-over accidents in the States?
The unseemly spectacle of Firestone and Ford each blaming the other for tyres that weren't quite up to spec, and a vehicle that was so sensitive to this that it would roll at the drop of a hat was sad to watch, and did nothing for the reputation of either company. It also came as no surprise to me at the time ...
I just read an article in the Age newspaper comparing the current model Forester, RAV4, CRV and Mazda CX-5. The author states with great authority that the Fox has no air-con vents to the rear ... Funny that. They must have removed these from this model, because even my Impreza had two, and our SG and SH models each have four - two each side.
How can one believe this sort of sloppy inspection and writing?
