Jacko
Hi Guys,
I am finally looking to setup my dual battery. I purchased a 100 a/h battery and battery box to sit in the boot. After reading all the threads and everything I can find online, my preference is for a Volt Sensitive Relay with override switch in the cabin.
My problem and question is that after fixing a volt meter in the car to monitor my battery voltage, I have realised my system sits somewhere between 12 and 13 volts when the engine is running and around 11.5 to 12.5 when the car is off.
The VSRs usually have a cut-in at 13.2 and cut-out at 12.7 so to me it seems my second battery would rarely get charged?? Are my numbers too low and should I presume my battery or alternator need a check? Or is this usual for a Forester and a VSR is not the way to go?
Cheers,
Jacko.
Cheers,
Jacko.
