NachaLuva
Product Developer
I've compiled a list of torque specs for my SF Foz, but I got them from my Haynes WSM which is US spec, also its '00-'06, so not necessarily the same as my AUDM SF. Wondering if anyone can point me to a website showing a complete list.
This is what I've got so far:
Ft-lbs Nm
Wheel nuts 66 90
Spark Plugs15.5 21
Engine Oil Drain Plug 33 44
Gearbox Drain Plug 32.5 44
Rear Diff Plugs 36 49
Thermostat Housing bolts 5 7
Oxygen Sensor 15 20
Gearbox to Engine Lwr Nuts 36 50
Gearbox to Engine Upr Bolts 36 50
Brakes Banjo Bolts 13 17.6
Fr Caliper Bolt 27 36.6
Rr Caliper Bolt 28 40
Fr Strut upper mounting bolts 15 20
Fr Strut to knuckle bolts/nuts 129 175
Control Arm Fr pivot bolt/nut 74 100
Control Arm Rr pivot stud/nut 140 190
Control Arm Rr bushing bracket bolts 184 250
Subframe Fr(3) & Rr(2) Mounting bolts 52 71
Subframe Middle(3) Mounting bolts 41 55
Rr Strut upper mounting bolts 23 30
Rr Strut to knuckle bolts/nuts 148 200
Trailing Arm to Body 74 100
Trailing Arm to Knuckle 67 90
Can anyone tell me if any of these are wrong for an SF Foz?
Needing:
Engine Xmember to body
Gearbox Xmember to body
Rr Xmember to body
Moustache bar
Any others you might think are useful....
It might also help others if a list of torque specs for other models were done.
EDIT: Well I did have these nicely lined up for easy viewing, but it seems posting removes the blank spaces
Ft-lbs Nm
Wheel nuts 66 90
Spark Plugs15.5 21
Oxygen Sensor 15 20
Needing:
Rr Xmember to body
Moustache bar
