NachaLuva
Product Developer
Just got a digital tyre gauge with an inbuilt deflator.
Its called a Slime Digital Tyre Gauge, comes with a 30cm hose, 4 pressure presets, pressure hold or dynamic mode, backlit display & most importantly...an inbuilt deflator!
https://www.slime.com/shop/digital-gauge-with-extended-hose-20071/
Its a lil complicated if you want to use its features & the instructions arent the clearest, but set to "dyna" mode (shows pressure in real time) its pretty simple. Turn it on, attach it to the valve stem & press the deflator to your desired pressure :biggrin:
There are presets which I set to 36 (for airing back up with hot tyres), 28, 22 & 16PSI. It beeps if the pressure reads over the preset.
The hose coils around the gauge in a tidy keeper, seems to be well made & makes airing down simple, easy & fast. At $40 its a lil expensive but its the only digital gauge I've found with a deflator
