Will 15" rims fit on a XT Forester
not the steel rims, you have to grind down the front brake callipers to fit them on. (kevin has s thread some were) or if your lucky enough find a set of 15inch alloys from the 1st gen limited
I've put them on my car and they are so close they turn by hand but do scrape.
Less than 1mm would need to be removed. I'll prolly get a set for cheap track day action.
Has anyone actually ground the 1mm away and used them? Or is that not really enough clearance to be used for offroading, I suppose debris build up could be a problem
any rally rims that fit the wrx, will fit onto the forester
That's exactly what I figured. Plus I love the look of white rally wheels! Now I just need to stop spending money on other priorities, and invest in rally wheels for my Forester.
Wonder if there are any good sources for used rally wheels in the US?
You'll need to stick with +48 or slightly less offset (minus 2-3mm maybe) otherwise you'll pull the rim & tyre closer to the spring perch
G'day dtz :welcome:
That link doesnt work for me. You have WRC wheels? Cool :cool:
PS: If you add your location in User CP it will help us answer any questions you might have. You can also add your Subie type in your profile using Edit Signature to tell us a bit bout your ride ;)
