not needed. the turbo in your foz will continue to be water cooled after the engine is off . I think its called thermal siphoning that is why the coolant check tankis higher than the turbo. drive your car gently for a minute or 2 before shutdown after a hard drive. Turbo timers are for old tech and riceboys
You don't need a timer if you do one thing after a hard drive. before shutting off the car count slowly to ten. By by that time the turbo would have spooled down. This will extend your turbo life.
