NachaLuva
Product Developer
I was watching a doco on Ferrari F1 the other day when they mentioned a Ferrari 3.0L Flat 12 Boxer engine!
My jaw dropped!
Thats right...Ferrari F1 designed, built & used a boxer engine. Not just any boxer engine but a 3.0L 12 cylinder boxer...a 3.0L H12
I reckon that would give Venom & Dulagarl a run for their money :rotfl::rotfl::rotfl:
Engine (1970):
Designation: Type 001
Type: Rear-mounted. 180° V12, light alloy cylinder block and head, aluminium wet liners, 112 mm connecting rods, water cooled
Bore & Stroke: 78.5 x 51.5 mm
Unitary and Total Displacement: 249.25/2,991.01 cc
Compression Ratio: 11.8:1
Max. Power Output: 460 bhp at 12,000 rpm
Timing Gear: 4 valves per cylinder, 2 overhead camshafts per cylinder bank driven be gears off the back of the engine
Fuel Feed: Lucas indirect injection
Ignition: Single plug, distributor, coil and Dinoplex electronic capacitive discharge
Lubrication System: Dry sump with radiator
Thats right...460bhp at 12,000rpm!!!
Not bad for 1970!
By the end of development a decade later, it had reached 515 bhp at 12,300 rpm, partly due to the short stroke:
Engine (1979):
Engine: Type 015, rear-mounted 180° V12, light alloy cylinder block and head, aluminium wet liners, 112 mm connecting rods, water cooled
Bore & Stroke: 80 x 49.6 mm
Unitary and Total Displacement: 249.3168/2,991.801 cc
Compression Ratio: 11.5:1
Max. Power Output: 515 bhp at 12,300 rpm
Timing Gear: 4 valves per cylinder, 2 camshafts per cylinder bank, gear driven off the rear of the engine
Ignition: Single plug with coil-ignition and Marelli Dinoplex electronic capacitive discharge
More info here:
https://www.f1technical.net/f1db/cars/256/ferrari-312b
My jaw dropped!
Engine (1970):
Not bad for 1970!
Engine (1979):
More info here:
